Browse Forums Kitchen Corner 1 Jul 14, 2009 3:33 pm Hi, I am looking to install a dishwasher and have been look at this post (viewtopic.php?t=11496).. I am looking at doing the same sort of thing, removing a cupboard next to the sink. I have measured it and it is big enough for a dishwasher. I started by removing the doors and all the screws inside the cupboard but even with the screws out I can't get the carcass to move at all. Would it be glued together aswell? Anyone think I can get this out without destroying anything? There is a powerpoint in the cupboard to the right and the pipes in the cupboard to the left so it looks like the cupboard was designed to fit a dishwasher just can't get it apart. Thanks. Re: remove kitchen cupboard carcass 2Jul 14, 2009 9:18 pm Burnz316, Check the following: - have you removed the kickboard - sometimes carcass are screwed together from the neighbouring carcass. So, check adjoining carcasses' walls for screw heads. Chris Re: remove kitchen cupboard carcass 3Jul 15, 2009 10:39 am Quote: Check the following: - have you removed the kickboard - sometimes carcass are screwed together from the neighbouring carcass. So, check adjoining carcasses' walls for screw heads. what's the kickboard? yeh checked the two cupboards next to it, no screws to be seen.. thanks Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3439 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5928 |
