Browse Forums Kitchen Corner Re: remove kitchen cupboard carcass 3Jul 15, 2009 10:39 am Quote: Check the following: - have you removed the kickboard - sometimes carcass are screwed together from the neighbouring carcass. So, check adjoining carcasses' walls for screw heads. what's the kickboard? yeh checked the two cupboards next to it, no screws to be seen.. thanks Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1385 Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3446 |
