Browse Forums Kitchen Corner 1 Jul 10, 2009 2:56 pm Hi all! I need my canopy rangehood installed. It will need to be ducted to outside wall (brick). The ceiling is angled so I guess the ceiling needs to be cut on an angle The wiring and power connection is done. Can anyone recommend someone to do the job...in Greensborough Vic. Thanks That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8630 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5420 Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2089 |
