Browse Forums Kitchen Corner 1 Jun 28, 2009 9:02 pm Hi All Can anyone suggest a reliable tradie to me. I am putting in a new kitchen and my breakfast bar sits on exposed bricks and unfortuantely due to the house being older and the new bench thicker than the existing I need a Reliable tradie that can knock the top row of bricks off and cut them back by so many mm and then put the bricks back on. Hopefully then when new bench is done it will sit flush as does the existing!!! Nervous about who I use as if they stuff it up I'll have a wobbly bench!!! Does anyone have anyone they have used and can recommend for this job????? Please help there are sleepless nights over this project.... Re: Benchtops on exp brick - NEED RELIABLE TRADIE - PERTH NOR 2Jun 28, 2009 9:27 pm Would it not be better to gauge them down where they are? Dustless diamond saw Also your bench won't be wobbly if you strategicly place some kerry packers around. Where you are coming from is where you are going to... Re: Benchtops on exp brick - NEED RELIABLE TRADIE - PERTH NOR 3Jul 02, 2009 12:09 am The people doing the kitchen did mention this option however he said it would be quite messy if we did it where they are???? Dustless diamond saw sounds as though it would do the job though ?! What are kerry packers??? Only Kerry packer I know doesn't sit around benchtops and is quite wealthy No offence on the kerry packer thing just feeling a little humourous tonight as renovating is giving me headaches and need a bit of a laugh here and there when I can! Should I just get a handyman to do this or is there someone better qualified to hire for this job? Would appreciate any further advice you can give. Thanks J Baby onc_artisan Would it not be better to gauge them down where they are? Dustless diamond saw Also your bench won't be wobbly if you strategicly place some kerry packers around. Re: Benchtops on exp brick - NEED RELIABLE TRADIE - PERTH NOR 4Jul 02, 2009 12:21 am Ol'Keza... He comes in handy for a wedge 3 points level is perfect Dustless is only so good, but you have a job to do, and can be cleaed up How much are you going to be cutting off? Cut it in one pass with a wrecking saw 100mm. Where you are coming from is where you are going to... Re: Benchtops on exp brick - NEED RELIABLE TRADIE - PERTH NOR 5Jul 02, 2009 12:45 am Can't remember now how many mm needs to go at the moment ! Any ideas on whether I should get a handyman or someone specific for this job ??? No idea when it comes to things like this???? onc_artisan Ol'Keza... He comes in handy for a wedge 3 points level is perfect Dustless is only so good, but you have a job to do, and can be cleaed up How much are you going to be cutting off? Cut it in one pass with a wrecking saw 100mm. Unless there were unforeseeable issues with the site, I dont think you should have to pay for contractors errors or poor planning. I'd probably try and be reasonable and… 5 4528 2 8358 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12127 |
