Browse Forums Kitchen Corner 1 Jun 25, 2009 1:05 am Hi all, I want to ask whether it is a wise idea to change all the benchtops in the wet areas from laminex to say caesarsone or granite after handover, or should I get it done by the builder. Would it be cheaper to do it after handover than say if builder do it? Has anyone done this before? Thanks in advance for your help. Re: Changing Benchtops after handover??? 2Jun 25, 2009 10:19 am Changing tops after handover using independent people can be cheaper but if a builder is finisihng your house off for you he will also be putting the splashbacks on, glass or tile. Since it is all brand new I would advise that you try and get your final top e.g. Caesarstone installed before your splashbacks go in, one way or the other. Cheers, Earl Re: Changing Benchtops after handover??? 3Jun 25, 2009 11:07 am Thanks Strumer for the information, can I ask whether it is a requirement to have the splashbacks in kitchen and bathrooms in order to get occupation certificate? Can I tell the builder to leave the splashbacks out? Thanks any help is much appreciated. Re: Changing Benchtops after handover??? 4Jun 25, 2009 9:13 pm Thats what I was thinking... If your going to change it after handover then I wouldnt bother getting tiles done around it. Is it possible to have handover without any tops or splash back at all???????????? Then you can take your time and do what you want after I thought the main requirements was to have the toilet and baths and stove plumbed for occupancy? Know where your going in life............... you may already be there Re: Changing Benchtops after handover??? 6Jun 25, 2009 11:55 pm Yeah hopefully the splashback is not a requirement to get occupancy certificate and can be left out to be done after handover, lets pray. Re: Changing Benchtops after handover??? 7Jun 26, 2009 8:17 am We've left the splashback for after handover. No probs. What will happen is that you will get an INTERIM OCCUPATION CERTIFICATE in the meantime, which will allow you to move in. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Changing Benchtops after handover??? 8Jun 27, 2009 2:20 am Southies We've left the splashback for after handover. No probs. What will happen is that you will get an INTERIM OCCUPATION CERTIFICATE in the meantime, which will allow you to move in. Thanks Southies for the info, you think the regulation in Victoria will be the same?? I hope so. How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 12353 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5819 Hi all, I've received the unwelcome news that our certifier (BCA Certifiers) has merged into the McKenzie Group. A quick Google revealed McKenzie is the mob that… 0 4453 |
