Browse Forums Kitchen Corner Re: Splashback / overhead cupboard height regulations 7Jun 16, 2009 5:01 pm Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Splashback / overhead cupboard height regulations 8Jun 16, 2009 5:07 pm Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Splashback / overhead cupboard height regulations 12Jun 16, 2009 10:13 pm esg Thanks for your reply boobalator. Can you point me in the direction of where you're getting these measurements? I've been searching for something concrete, but can't find anything The rangehood will be a minimum of 660mm above the hob (as specified by the installation instructions). I've done some measurements re the distance from hob to overheads - * Horizontally they are just over 210mm from the centre of the closest hob. * Vertically they will be about 450mm So by the sounds of it, because they overheads are more than 200mm horizontally from the hob then the height is ok. Does that sound right? It's 200mm horizontally to the EDGE of the closest gas ring. This should be ok though, usually this distance is a lot less, but your stove is quite large. Just make sure you use the rangehood every time you use the stove, and you should be ok. Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1515 If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26171 You need to reference the manufactures installation guide, your supplier may have strengthened the base where it is not required to sit on a bed. 1 1834 |
