Browse Forums Kitchen Corner Re: How big is a standard microwave cut out?? 4May 25, 2011 10:29 pm Grinder I got the measurements off the net but not sure how big my microwave cut out is, we haven't moved yet. PCI tomorrow I will take the tape measure with me, I hope it fits, it would look so shmick Re: How big is a standard microwave cut out?? 6May 25, 2011 11:16 pm You're stock standard microwave cubby is 600w x 390h. Sadly that corker of a Bosch won't fit in a standard cubby. Matt's Brando: viewtopic.php?f=31&t=46340 Started March 30th 2011 PCI July 15th Re: How big is a standard microwave cut out?? 8May 26, 2011 1:45 pm Mrs P, your kitchen looks lovely. Mmm, undermount sink..... Sorry, no help at all with your question, just had to tell you how nice it looks. ![]() Re: How big is a standard microwave cut out?? 10Jun 02, 2011 9:58 am Just wondered if any one knows how we stand with our microwave cut out. The plans say 634 when I have measured the internal measurement it measures 550. The microwave we have bought is not going to fit. We will be doing the walk through in the next 2 weeks. Where do we stand with this. It has an essa stone base but the internal sides seem to have extra panels which are making it narrow internally. These look like they could be removed but unsure if they are offering support to the cupboard above. Any opinions/comments would be much appreciated. Cheers. Re: How big is a standard microwave cut out?? 11Jun 02, 2011 12:41 pm Just wondered if any one knows how we stand with our microwave cut out. The plans say 634 when I have measured the internal measurement it measures 550. The microwave we have bought is not going to fit. We will be doing the walk through in the next 2 weeks. Where do we stand with this. It has an essa stone base but the internal sides seem to have extra panels which are making it narrow internally. These look like they could be removed but unsure if they are offering support to the cupboard above. Any opinions/comments would be much appreciated. Cheers. The external size of the fascia of a built in Microwave can be very different to the external size of the microwave 20mm back from the front. I am doing a Microwave at the minute that is 600mm wide at the fascia but only 520mm wide behind it. You really need the microwave there to check if it will fit. The online specs from most appliance suppliers are terriable. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: How big is a standard microwave cut out?? 12Jun 02, 2011 1:44 pm The installation guide here https://portal.bsh-partner.com/portal%2 ... LFRAME.HTM Says that the cavity should be min 450mm internal height, 568mm (560+8mm) internal width and 5500mm internal depth. Building Standards; Getting It Right! Theres no specific code but consider hot liquids being removed from the microwave, the higher the more likely itll spill. Aim for no higher than 1400 to the base. 1 204828 No I don't believe it is too steep. We are doing one with similar fall to yours in Lindfield ( see attached plans) It will need to be split level and you will need to… 5 58836 Stanks Bimbob was spot on with his post. You will need a dedicated circuit the same as an induction cooktop basically. The great thing though is typically most meter… 3 20689 |
