Browse Forums Kitchen Corner Re: powerpoint on waterfall island bench 21May 19, 2011 11:18 pm Our waterfall edge island bench has a Saturn D/P in each of the top corners under the 30cm overhang for occasional rather than constant use. If we need power on the island bench we don't have to worry about tripping over extension cords but to the casual observer they're hidden by the overhang. When the slab was poured we included an electrical conduit for the electrical cable. We also considered the benchtop popup sockets but didn't want to drill holes in our benchtop. We would have also had to shorten one of the drawers to allow for the unit to fit inside the cabinetry. Re: powerpoint on waterfall island bench 22May 20, 2011 4:11 pm we have one on the end of the bench. The stonemason had to drill the hole rather than the electrician. (there's no face plate/surround on the powerpoint yet). http://i69.photobucket.com/albums/i80/danielt25/New%20House/IMG_0134.jpg Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: powerpoint on waterfall island bench 23May 25, 2011 9:20 pm we are looking at using one like the last picture on this link http://www.carliellekitchens.co.nz/gall ... lery4.html Re: powerpoint on waterfall island bench 24May 26, 2011 10:11 pm chook07 we are looking at using one like the last picture on this link http://www.carliellekitchens.co.nz/gall ... lery4.html Looks great, but wouldn't it cost a lot to make a hole in the bench for it? Re: powerpoint on waterfall island bench 25Jun 02, 2011 5:51 pm Will it cost much? I havent gone to prestart yet, but was quoted $150 to drill a 102mm hole in an essa stone benchtop required by the EVOline port in that picture. I was quoated $320 for the standard model port (there is a deluxe model with a metal top instead of plastic) I was also looking at the pop up clipsal points (single power point). At the end of the day, I dont think there is much in it. Re: powerpoint on waterfall island bench 26Jun 02, 2011 6:29 pm theyetti Our waterfall edge island bench has a Saturn D/P in each of the top corners under the 30cm overhang for occasional rather than constant use. If we need power on the island bench we don't have to worry about tripping over extension cords but to the casual observer they're hidden by the overhang. When the slab was poured we included an electrical conduit for the electrical cable. We also considered the benchtop popup sockets but didn't want to drill holes in our benchtop. We would have also had to shorten one of the drawers to allow for the unit to fit inside the cabinetry. I like the sound of that. Would you happen to have a photo by any chance? DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6587 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11701 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31277 |
