Browse Forums Kitchen Corner 1 May 25, 2009 2:35 pm Hi everyone, I have attached the standard basic kitchen plan for the home we are building. We like that the kitchen is tucked into this area adjacent to the main living areas, but not right in the middle of it all, but it means that the area we have to work with is quite restricted. We are considering whether to have a WIP with a door where the current pantry is and build the WIP behind the existing back wall of the kitchen - does that make sense? I am also trying to work out if there is anyway to better configure this space to get the sink off the front bench, whether to make the front bench an island or whether to leave joined and move the sink on the bench up against the wall? - you may have guessed - I am trying to work out how to get more bench space... Any ideas, thoughts, suggestions would be much appreciated and welcomed! Please let me know if you have any questions... Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with kitchen plan - please! 2May 25, 2009 3:30 pm Im a big fan of walk in pantrys!!! Do you have a lot of room behind the wall. If so, you could make the existing pantry a doorway and in the WIP ( if its big enough) you could also keep the fridge in there. That may give you some extra bench space in leiu of the existing fridge space. or the existing bench space you have along the wall... continue the bench around underneath the window and move the island bench to connect up to it. So the entrance to you kitchen is on the other side I dont have access to photobucket at work. so i posted a pic of what i mean on my blog. Have a look!! http://sunnycoastdreamhome.blogspot.com/ Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11251 we need accurate dimensions as well as the number of bedrooms and bathrooms needed etc to make specific suggestions but, based on estimated rooms sizes, it could be… 1 529 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14306 |
