Browse Forums Kitchen Corner 1 Apr 24, 2007 10:27 pm ive been offered some wall cabinats which are near new but with laminate doors. i was thinking i'd take them and replace the doors but my question is perhaps can i paint them somehow to make them match my other Polyurethane doors? Re: getting a diy Polyurethane look to match existing doors 3Apr 25, 2007 7:07 am You can't paint two pack yourself without a fair amount of equipment and a relevant permit.
Achieving a finish that matches your existing polyurethane with another product is a big ask. Melamine is manufactured specifically to make it very difficult for anything to stick to, so I wouldn't really consider painting the exisitng doors (if that is what you mean). There ARE paints that will work on melamine and laminates, but it is unlikely that they will come up looking like your poly doors. The best you can hope for is to take an existing coated door to a doormaker and get the profile reproduced and then try and get someone to match the paint - either the doormaker if they also paint them or a third party cabinet spray painter...you could also try a panel shop for the painting - but neither of these options is cheap. Cheers, Earl Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3073 4 11208 1 19722 |
