Browse Forums Kitchen Corner 1 May 07, 2009 12:24 pm i have had square black diamond gloss benchtops in my new house. where the top meet the side on the edges on the benchtops you can see the brown from the bottomside ofb the diamond gloss?? does this make sence?? what should the edges look like?? Re: advise please 2May 07, 2009 12:32 pm Do you mean on the underside of your bench overhang? ie if you have an overhang to create a breakfast bar is it underneath? If this is what you mean then it is perfectly normal. Or do you mean where your benchtop is alongside a cupboard and the overhang juts out - and you can see it on the bit on the side? Because if this is what you mean then no it should be that way. Normally your kitchen installer will use an Γ―ron-on / glue-on" trim in the same material to make it look like a solid slab. Sorry if this is not what you mean at all but these are the only things I could imagine it would be. Some things are worth waiting for. Re: advise please 3May 07, 2009 1:31 pm I think you mean the substrate where the edges meet. Like in my pantry benchtop shown here: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It's always going to happen on square edge benches. However it shouldn't be so noticable on a black one. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." β Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: advise please 4May 15, 2009 2:39 pm This is an issue with square edge tops, laminex do a tightform b/top that has a radius top and bottom, some of their diamond gloss colours can be done this way. Basically your kitchen company buys the slabs from laminex and cuts them to suit.No laminate joins I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 7964 Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the… 0 8568 Thankyou so much π I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK π 2 7158 |
