Browse Forums Kitchen Corner 1 May 02, 2009 7:23 pm Hi Was told today that if I have a set of kitchen draws up against a solid wall it needs something on the side of the draw that is next to the wall. What are they talking about? Also how thick does it have to be? Thanks Re: Kitchen Design Question 2May 02, 2009 8:26 pm Its called a filler panel. Standard size is usually 30 - 40mm wide. The cabinet maker also uses it as a bit of a buffer in case the walls are a little out of plumb. So they can trim it down on site to sit flush against the wall with no gaps. Built with Bentley homes in Doreen All moved in Dec 2009 Now for the garden! Our stuff so far viewtopic.php?f=31&t=16532 Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15293 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9948 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13817 |
