Browse Forums Kitchen Corner 1 Apr 22, 2009 1:36 pm Hello, I would like to ask if anyone could recommend a service repair for stone benchtop. I have lost my hope with my builder to have this stone benchtop repaired. I have been waited for so long, but no answer yet to come. This happened on the date of our settlement. The last inspection we did before the settlement, the cooktop was not installed. So we agreed on installing the cooktop on the settlement date. After we got the keys to our new home, the cooktop was installed but with some problems. It looks like the cooktop is bigger that the stone cut, and the guy who did the installation use the full force and the stone was moved slightly (see pictures). IMG_9949.JPG IMG_9950.JPG This is Essa Stone. I live in Melbourne at the moment, and if any of you could recommend a serviceman you can adjust my stone benchtop - that would be great. Cheers, Jon Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Finding Repairman to Stone Benchtop 2Apr 22, 2009 2:19 pm Ring your nearest Laminex office and make some noise about the builder. Having said that they will probably try to blame the installer (unless this was the builder) but the tops should have been cut to the size of the appliance so that this doesn't happen - unless the specification of the cooktop was changed after the tops were measured up. The tops were more than likely installed by a third party (not your builder) and it is in Laminex's interest to stay on top of this. However, in my experience, Laminex might not be springing to your rescue, but it is still where I would start. Cheers, Earl Re: Finding Repairman to Stone Benchtop 3Apr 22, 2009 2:30 pm hey cool2frost. Does the two pieces no move freely?? are they still joined. They would have been joined with 2pac glue and it looks like this was broken(This would be hard to break). Best option would be to remove stove push the top back in place and make opening bigger, reglue the join and put back in place. They then should sand/polish the join so it is not as obvoius on the edge. Re: Finding Repairman to Stone Benchtop 4Apr 24, 2009 5:25 pm Can you take a photo from inside the cupboard under the cooktop. The way a stone bench top is installed is there is a 19mm piece of chipboard or mdf screwed to the carcases first other wise known as a substrate, then the stone tops are siliconed to the substrate and left to cure. (24hrs) From what i can see in the photo's i would remove the cooktop and see if re-aligning is possible by loosening all the screws and try to push it back to the wall, failing this the splashback may need to have the grout/silicon cut at the bottom and the top removed and trimmed then replaced if there isn't enough clearance. Where are you located???? Ben LEADING THE WAY IN BUILDING AND CONSTRUCTION BUILDERSEDGE PTY LTD Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12921 Hi Kateo, Are you able to spare any of the tiles? Thanks Tony 10 11402 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7932 |
