Browse Forums Kitchen Corner 1 Apr 18, 2009 11:11 pm I had the builder remove all splashback tiling in the kitchen because I am having my own glass splashback installed. This is the colour scheme of my kitchen and what it looks like. Benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cupboards/drawers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Actual kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I would want the splashback to be installed on the wall behind the cooktop and also the walls on the ends on the bench. I have a a couple of ideas in mind - one would be to have the splashback end around the height of the rangehood so that I could later have overhead cupboards put in, or have the splashback extend all the way up. I'm wondering since I have these particular laminate colours, how is it going to work with installing my own overhead cupboards later? What type of cupboard could I install that would work with the colour scheme? And probably my most important question that needs to be answered, what colour glass for the splash would you suggest, especially if I was to install overhead cupboards. I'm guessing that if was to choose a particular colour glass for the splashback, I'd need to stick with that colour for the overheads. For example, if I went with a black glass then the overheads should also be black. Suggestions please! Built with Commodore Homes - The Fusion completed April 2009 (with modifications) Yes I have moved! Will update as soon as I can...no internet at home right now!!! Sooty's House - viewtopic.php?f=31&t=19462 Re: Suggestions on the splashback and overhead cupboards 2Apr 19, 2009 8:18 am I'm not the best with colours because I tend to stick to very neutral colours If it were me I would probably do the overheads in a light colours - white, off white, light grey to give a contrast to your bottom cupboards which actually look darker than first thought in the picture of your kitchen. I would then choose a basic colour for the splashback - a light shimmery silver/white, a light sandy colour....nothing to outrageous because your benchtops and cupboards already have a bit going on. Good luck, I'm sure someone better with colours will come along and give you better advice My karma ran over your dogma Re: Suggestions on the splashback and overhead cupboards 3Apr 19, 2009 3:13 pm Thanks. You're right, the cupboards are much darker than what you'd think looking at the sample. Originally I was going to do that colour for the benchtops and the lighter colour for the cupboards but thought it might end up too dark, which turned out to be a good decision to make because I have a very large island bench and it really would have been too dark. I thought of choosing a bold colour for the splashback to really stand out (for example, like a ruby red) and lift the steely tones, but then it would make it much harder to find suitable overheads. So for now light and white is sounding good. Built with Commodore Homes - The Fusion completed April 2009 (with modifications) Yes I have moved! Will update as soon as I can...no internet at home right now!!! Sooty's House - viewtopic.php?f=31&t=19462 Re: Suggestions on the splashback and overhead cupboards 4Apr 19, 2009 6:43 pm Maybe go with a mosiac tile splash back? That way you can have a bit of colour thoughout but making it quite interesting? There's so much out there at the moment (we just spent the weekend looking!) that it's so hard deciding on one! If you go a mosiac, that way you can then stick to the same overheads as you have below or maybe even have the benchtop colour as your overhead? Building our dream home - H3nley Ascot 384 Painting done - electrical, alarm and tiling being completed!! viewtopic.php?f=31&t=17939 Re: Suggestions on the splashback and overhead cupboards 5Apr 19, 2009 8:50 pm I didn't want to get anything tiled which is why I deleted the builder's tiling. I want it to be just one flat smooth surface to wipe over clean. My aunt has mosaic tile splashback, it does look very nice though. Built with Commodore Homes - The Fusion completed April 2009 (with modifications) Yes I have moved! Will update as soon as I can...no internet at home right now!!! Sooty's House - viewtopic.php?f=31&t=19462 Re: Suggestions on the splashback and overhead cupboards 6Apr 19, 2009 9:49 pm sooty I didn't want to get anything tiled which is why I deleted the builder's tiling. I want it to be just one flat smooth surface to wipe over clean. My aunt has mosaic tile splashback, it does look very nice though. I didn't even think of the cleaning!!!!! Thanks for that tip..... might have to go back to our drawing board Building our dream home - H3nley Ascot 384 Painting done - electrical, alarm and tiling being completed!! viewtopic.php?f=31&t=17939 Re: Suggestions on the splashback and overhead cupboards 7Apr 20, 2009 1:40 pm Macca's home sooty I didn't want to get anything tiled which is why I deleted the builder's tiling. I want it to be just one flat smooth surface to wipe over clean. My aunt has mosaic tile splashback, it does look very nice though. I didn't even think of the cleaning!!!!! Thanks for that tip..... might have to go back to our drawing board I suppose it depends on whether you really cook or not. But if you do cook it makes it a lot easier than having to clean between the grout. Built with Commodore Homes - The Fusion completed April 2009 (with modifications) Yes I have moved! Will update as soon as I can...no internet at home right now!!! Sooty's House - viewtopic.php?f=31&t=19462 Re: Suggestions on the splashback and overhead cupboards 8Apr 20, 2009 1:58 pm If cost isnt the biggest factor, how about having glass doors on the top units? If you choose acid etched glass doors then have the splashback to match, white backing on clear glass! If not, have a coloured splashback instead, it will all go and look spectacular especially if you get lights put inside the units Kitchens are like finger prints, no two are ever the same!! SmartPack did the kitchens for Channel 9's Home Made TV Show Re: Suggestions on the splashback and overhead cupboards 9Apr 20, 2009 2:02 pm Yes I do like glass doors and that was the plan, to get overheads with glass doors. I'm not exactly sure of what you're suggesting, but are you saying to have a clear glass splashback with the white ball behind it? If I get a coloured splashback I'm just worried about it clashing with the colour of the cupboards or there being too many colours. Built with Commodore Homes - The Fusion completed April 2009 (with modifications) Yes I have moved! Will update as soon as I can...no internet at home right now!!! Sooty's House - viewtopic.php?f=31&t=19462 Hi, Can anyone give me approx. price for overhead cupboards. TIA 0 16545 ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 15142 Hi, Looking to add an ensuite to one of the bedrooms and make it a Master BR. Please see the attached current floorplan. Need suggestions on what's the best way to do… 0 7329 |
