I'm thinking of angling the stove / hotplates into the corner. I'd angle it at 45-degrees and angle the counter to match. Has anyone done this (or seen it). Are there any dangers I should know about ?
Thanks
Browse Forums Kitchen Corner 1 Apr 01, 2007 1:46 pm I'm thinking of angling the stove / hotplates into the corner. I'd angle it at 45-degrees and angle the counter to match. Has anyone done this (or seen it). Are there any dangers I should know about ?
Thanks Re: Stove in the corner ? 2Apr 01, 2007 7:57 pm This is not an unusual decision for a considered kitchen layout.
The floor corner unit underneath the top (assuming it is 6oo wide) will need to be 1000 x 1000 along the walls. One thing you do need to consider is the triangular corner behind the cooktop. This will effectively become "dead space" as you can not really reach across your cooktop to access this area (when you are cooking). One effective option for this is to raise the back corner into a shelf area, making it higher than the top in front of it. This allows some useful cooking items to be placed behind the cooktop and still be accessable. Alternatively you can also place a false wall across this corner to deal with the dead area. Cheers, Earl Re: Stove in the corner ? 3Apr 01, 2007 8:11 pm Thanks Earl, that's reassuring. I think I'd go for the 'fill' suggestion since they'd need to be a splashback of sorts too. (I hear that glass is the easiest to clean).
Like your site by the way. Excellent animations. Re: Stove in the corner ? 4Apr 01, 2007 9:35 pm Thanks for the feedback on the site - those animations took a while to build and it is nice when people respond to them.
Re your "fill in" wall; great idea, and yes a splashback is a good thing to hang behind a cooktop across a corner. Glass is a great splashback material and worth the investment. One tip, if you want to save costs on a glass splash try to avoid placing too many power points in the glass - this is where costs mount up. Consider mounting GPOs elsewhere, such as underbench or inside cupboards. Another advantage of filling the void is being able to mount a range hood above the top and still against a wall. If you are lucky you will also be able to use this void to duct your range through, as well as any other troublesome services you might have. Cheers for the shoutout, I hope it goes well for you. Feel free to send me a layout if you have any questions. Earl Re: Stove in the corner ? 5Apr 17, 2007 9:16 pm Thanks for then idea cabinfever. I have this horrible 70's kitchen with x 4 burner stove literally stuffed into the corner and a high cupboard beside it. It's like cooking in a cavern.
Might review the angled option see how that looks for my renovation design. and ditto like your web site Earl. Steve The gap can be adjusted so it's tighter. You can definitely set up corner cabinets to have the same gap as standard doors. 2 13454 4 14128 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 4741 |
