Browse Forums Kitchen Corner 1 Apr 14, 2009 4:29 pm Hi everyone, Just wanting to know what the distance is between your island bench and the rest of your kitchen. I am asking this with one eye closed - I'm not sure if I need to know the answer to this as I may be completely wrong and may have stuffed up my kitchen - I hope not. Anyway, we have an L-shaped kitchen with an island bench in the middle. The island is 2100 x 1200, so fairly large and no sink/cooktop on it. When planning the kitchen I came up with the distance of 1200 between the island and the other worktop. Is 1200 too much? I hope not - and if so I hope I have time to change mine! Thanks very muchly.... Jilly Re: Island worktop question 3Apr 14, 2009 5:45 pm yay! another tape measure question I have 1500 between my back wall bench and my front bench, it is a u shape kitchen, not an island bench as such, and there is nothing on the front bench. I seem to remember one of the kitchen guys answering this quesion before and they recomended minimum and maximum distances - obviously you want them far enough to be able to move easily between them but close enough to be part of same working area. Of course, I cant actually remember anything useful, like what the distances were Re: Island worktop question 4Apr 14, 2009 6:06 pm I would recommend min. 1000mm, max. 1500mm. Cheers, Earl Re: Island worktop question 5Apr 14, 2009 6:33 pm Thanks guys So Earl - I'm in the range then? And that 1200 of mine is from edge of bench to edge of bench - (Floor space of 1200 I guess you would say). It was just niggling at me that space and I was hoping I wasn't really out with it! So Thanks again! DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6592 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9971 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6157 |
