Browse Forums Kitchen Corner Re: Is it safe to install a 700mm undermount with a 900mm cooker 2Mar 30, 2009 4:57 pm I always thought an undermount referred to an undermount oven, but you couldn't have that with a freestanding oven what do you refer to when you say 'undermount'? "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Is it safe to install a 700mm undermount with a 900mm cooker 3Mar 30, 2009 5:08 pm I'm a bit confused too. Do you mean a 700mm intergrated rangehood for a 900mm cooktop? Mrs B Re: Is it safe to install a 700mm undermount with a 900mm cooker 5Mar 30, 2009 6:14 pm Your ranghood should at least be the same size as your cooktop, preferably larger. It won't be effective if it's smaller. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Is it safe to install a 700mm undermount with a 900mm cooker 6Mar 30, 2009 6:49 pm I'd like it to be the same size but can't seem to find one with the switch underneath. All the 900mm ones i've seen have the switch on the outside panel. B/c it'll be boxed up i won't be able to access the switches. Anyone know where I can get one? Re: Is it safe to install a 700mm undermount with a 900mm cooker 7Mar 30, 2009 7:00 pm We are also installing a 900mm free standing oven and have to upgrade the rangehood to a min 900mm also it will be ineffective any smaller. Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Is it safe to install a 700mm undermount with a 900mm cooker 8Apr 01, 2009 11:46 am ILVE make a new undercupboard rangehood in 90cm called CU79. Re: Is it safe to install a 700mm undermount with a 900mm cooker 9Apr 01, 2009 12:23 pm i have a 900 under mount bosch range hood, the buttons are on top of the part that slides out if that helps. i take it you would still have a 900 range hood cupboard rather than just a 700? My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 11317 2 15492 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3519 |
