Browse Forums Kitchen Corner 1 Mar 26, 2009 9:17 am We're having an undermount double sink in our stone island bench. I really wanted a 'built in' soap dispenser, but with the undermount sinks there's no room on the sink itself. I'm thinking something along the lines of this: http://www.sinkwarehouse.com.au/product ... prodid=344 Has anyone had experience with the soap dispenser installed into the stone benchtop next to the sink, rather than in the actual sink? Got photos you want to share? If we're put on this earth to help others, what are the others here for? Re: Under bench mounted soap dispenser 2Mar 26, 2009 10:39 am Honestly.... that is a very simple job... all you would need to do with the stone top would be to drill out a 30mm hold with a diamond drill bit...which your stone mason will gladly do for you... and its pretty much plug and play from there on in...will be a nice neat finish and wont cause you any drama'z... literally to get that dispenser in place and installed would take 15minutes with all the tools...which is pretty much water spray bottle,diamond drill bit and a heavy duty drilll and some really still hands... !! then you jus mount your dispenser and off you go... i like the idea tho..might put it in my kitchen too !!! Jeremy@SSP.Stones SSP Stones Pty Ltd, Detailed Manufacturers of all stone materials. Kitchen Benchtops, Bathroom Reno's, Floors, Facades and all other stone works. Re: Under bench mounted soap dispenser 3Mar 26, 2009 10:51 am Thanks Jeremy So we could get it installed separately later on, after the benchtop goes in? Or would it have to be done at the same time the holes are being cut out for the sinks? If we're put on this earth to help others, what are the others here for? Re: Under bench mounted soap dispenser 4Mar 26, 2009 11:29 am your better option would be to do it while the tops are goin in that way they can drill the hole off site and have it nice and clean for wen it goes in... but yea anytime you can do it... but your stone mason will be more then happy to do it while there installing it because they wont have to travel out a second time just to drill a hole. more then likely they will drill it out for free... !! But yea for that option pretty much just ask them you want the hole drill'ed to install your dispenser...show them were u want it ...and booya ...off you go! SSP Stones Pty Ltd, Detailed Manufacturers of all stone materials. Kitchen Benchtops, Bathroom Reno's, Floors, Facades and all other stone works. Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72313 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11674 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31248 |
