Browse Forums Kitchen Corner 1 Mar 09, 2009 8:03 pm Hi, I have a dinosaur of an oven i need to remove, its a fridgidaire caprice dual wall oven. I was wondering if this is an easy task or is it something for the experts to handle. Thanks Oscar Re: Electric Oven Removal 2Mar 10, 2009 4:53 am Its easy to do but you should have a licenced sparky disconnect the supply and make it safe.
You should be able to have an electrical contractor come in and remove it for around $150+gst (if its a massive oven then it will need two men to lift and dispose of) Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6700 Hi all. I'm thinking of installing an electric gate in front of this street front villa (link below). The gate would be between the bush on the left and the letter box on… 0 2778 Thanks good to know. How big is your tank? So you can set when your heat pump runs? How do you do that? How's the speed to heat? Is there such thing as instantaneous… 4 891 |
