Browse Forums Kitchen Corner 1 Mar 01, 2009 4:42 pm Hey guys,
My wife and I are just finalising the design with the drafty and she mentioned that if we were going to have a laminex benchtop on our 4100mm long island we would have to have a join as the longest single piece would be around 3500mm or somewhere around that? Does anyone have a 4m long benchtop in laminex without a join? We are happy to shorten it as 4m is very long but only if we have to. Cheers, Bailey. Energy efficient custom built house - Moving In 3 Weeks Re: Length of Island Bench 2Mar 01, 2009 4:52 pm Amerind make a laminate in lengths of 4900mm, which means with a rolled end they can be up to 4200mm long and 1000mm wide without a join.
Examples of the colours can be seen in the inForm range - http://www.gunnersens.com.au/products/d ... nform.html The gloss in the inForm range is standard HPL only and I would not recommend it for a benchtop - if you want a gloss benchtop that won't end up scratched and flat within six months you should consider having a look at Laminex Diamondgloss or Nevamar Gloss tops (they are the same product) http://www.gunnersens.com.au/products/d ... vamar.html, but the longest single sheet you can get is 3600mm, and that is without any postforming allowance. Cheers, Earl DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6584 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11694 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31266 |
