Browse Forums Kitchen Corner Re: Questionable connections for gas an electricity 3Feb 22, 2007 7:46 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Questionable connections for gas an electricity 8Feb 26, 2007 8:14 am The builder should have picked this up and got the plumber to redo those connections. Or did you employ the plumber your self or through a kitchen company?
If they won't fix it then you have a clear complaint to the regulators. In Victoria it is the Plumbing Industry Commission at this link: http://www.pic.vic.gov.au/www/html/7-home-page.asp Not sure what state you are in but it will be a similar story in every state. This is a safety issue and you must get it attended to ASAP. Building Standards; Getting It Right! It's all good. You can get both wye piece and the coupling with or without thread. The cost difference is negligible and means the plumber only has to carry the single… 1 4930 4 10823 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20232 |
