Browse Forums Kitchen Corner 1 Feb 09, 2009 11:10 am Hi everyone,
I have a bit of a dilemma. The standard configeration of our house has the stove in the island bench. As I think this is not practical in the long term, I would like to move the stove to the back bench. However, the only space that i can put it is right next to the fridge. There is probably a 20cm distance from the actual fridge. Is this safe to do? Any help would be great! Thanks in advance Idiots are fun, that's why there is one in every village! - Dr. House - Re: Can we put a stove next to the fridge? 2Feb 09, 2009 12:42 pm You will have heat and cold working against each other.
The fridge will have to work harder to keep cold Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Can we put a stove next to the fridge? 3Feb 09, 2009 12:59 pm Oh yes, you do have a point. Thanks
Ideally, how far away should the stove be from the fridge? Idiots are fun, that's why there is one in every village! - Dr. House - Re: Can we put a stove next to the fridge? 4Feb 09, 2009 1:27 pm wonderland Oh yes, you do have a point. Thanks Ideally, how far away should the stove be from the fridge? 300mm Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Can we put a stove next to the fridge? 5Feb 09, 2009 1:59 pm 30cm, I'll have to see whether i can push the stove further away from the fridge. Thank you for your advice! Idiots are fun, that's why there is one in every village! - Dr. House - Re: Can we put a stove next to the fridge? 6Feb 09, 2009 2:09 pm Kevin Brown You will have heat and cold working against each other. The fridge will have to work harder to keep cold Could you have some insulating material up against the side of the fridge? Re: Can we put a stove next to the fridge? 7Feb 09, 2009 2:53 pm joeygbh Kevin Brown You will have heat and cold working against each other. The fridge will have to work harder to keep cold Could you have some insulating material up against the side of the fridge? I have seen people stick alfoil to the side of the fridge...helps a bit... Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7522 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 15980 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20165 |
