Browse Forums Kitchen Corner Re: Sandstone kitchen bench top 2Jan 25, 2009 7:53 pm sandstone is very porous and no doubt would need maintaining like marbles and granites. I wouldnt think it would be very hard either.
Up to you really if you want to go down that path, but i would stick to less fuss - easy maintenance products. Kitchens are like finger prints, no two are ever the same!! SmartPack did the kitchens for Channel 9's Home Made TV Show Re: Sandstone kitchen bench top 3Jan 26, 2009 7:31 pm Sandstone countertops do look absolutely beautiful however they are very porous so you need to be very diligent when cleaning up spills.
You can get polymer sealers but you still need to be careful. A more expensive method involves honing, sealing and waxing but where water normally collects (around sinks) you will still need to wax the area say every six months or so. Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31364 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3867 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12560 |
