Browse Forums Kitchen Corner Re: Gas Wall Ovens 2Jan 19, 2009 7:08 pm Here is a link for you.
I have purchased from these people before and found them to be very helpful. http://www.appliancesonline.com.au/c-19 ... ovens.aspx If you choke a smurf... what colour do they turn? Re: Gas Wall Ovens 3Jan 19, 2009 8:02 pm Excellent site, thanks MM.
Great to look at for other appliances, & get dimensions, etc. Re: Gas Wall Ovens 6Jan 20, 2009 6:10 am It would seem the only brand around is Westinghouse? Anyone know of any others? Re: Gas Wall Ovens 7Jan 20, 2009 9:27 am Ilve also has built in gas ovens in 60cm and 80cm. And if you want an even bigger one, Viking has one in 90cm. Re: Gas Wall Ovens 8Jan 20, 2009 4:39 pm Thanks for that. Have also found a deLonghi as well, but it's only 66 litres.
Is that too small? Re: Gas Wall Ovens 9Jan 21, 2009 8:15 am great link miss muffit, you really have made my day, thanks alot, i really appreciate it.
__________________________________________ holiday villa Portugal Re: Gas Wall Ovens 10Jan 21, 2009 5:21 pm OK, so took time off work today to talk to a person face-face about my (limited) choices.
Went to Clive Peeters. Rather disappointed with the advice (or lack of). May have to rethink & look at underbench options. Re: Gas Wall Ovens 11Jan 21, 2009 5:32 pm Umm.. am I missing something? Why can't an underbench be on the wall?
When you say there are no gas wall ovens... I don't get it. Any underbanch oven can be put on the wall surely... Obviously not freestanding ones... but any others can be. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Gas Wall Ovens 12Jan 21, 2009 6:18 pm It seems not many are adaptable ... not sure as to exactly why. The ilve is one that can be, as is the new DeLonghi. Re: Gas Wall Ovens 13Jan 21, 2009 6:27 pm Why? What's to adapt? It's just set higher in the cabinetry.....
I can think of plenty of display homes where they use underbench ovens on the wall to show a variation on the kitchen layout. Off the top of my head: PD.... they use blanco M3tricon.... they use Technika Simonds.... Technika Carlisle..... not sure of their brand. I have seen all of those builders have their oven both underbench and in the wall. My appliances will be Kleenmaid and my oven, as with all Kleenmaid could be underbench or wall mounted. Here's an example from a PD home. The ovens are blanco. Usually they are underbench, but in this home they are one on top of the other in the wall. Or am I misunderstanding what you mean? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Gas Wall Ovens 14Jan 21, 2009 6:46 pm I'm not an oven expert (in fact, if I had my way, there would be NO OVEN!!!lol), d'k if there is a difference with wall mount a gas vs. electric, but will certainly look into it, thanks joles Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6271 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20496 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3871 |
