Browse Forums Kitchen Corner 1 Jan 18, 2009 7:13 pm Is it possible to have pot drawers under a bench that contains a sink?
We're having a large caesar stone bench top which will have a sink inside - I assume because of the piping under the sink we won't be able to have pot drawers underneath.... Anyone know more about this, because I personally think cupboards under kitchen sinks are useless and our sink is bang smack in the middle of our bench. Re: Pot Drawers - possible under a sink? 3Jan 18, 2009 9:08 pm You can also fit out cupboards with steel "drawer" systems and there are lots of options that would fit around most plumbing arrangements. As well as Blum, have a look at Hettich. Even Ikea or Bunnings have a few useful DIY items that might do the job.
http://www.blum.com.au/ http://www.hettich.com.au/79.htm Re: Pot Drawers - possible under a sink? 4Jan 19, 2009 9:28 am Blum has a wonderful under sink draw organiser - I want it Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Pot Drawers - possible under a sink? 5Jan 19, 2009 9:47 am You can probably use Spazio plumbing kit (Franke and Blanco stock them) to tuck the pipes to the back of the cupboard, you'll then have more space to install some drawers, but not the full depth ones. Maybe try drawers with depths of 45cm or 35cm like the ones from Blum or Ikea. Hello I'm remodeling my kitchen and evaluating ideas. We are in the last stages of drawing and I am now considering putting a pot filler tap in above the hob. Has anyone… 0 1368 yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6633 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36950 |
