Browse Forums Kitchen Corner Re: Kitchen bench Top paints 2Nov 24, 2004 9:18 pm FROM MEMORY I BELIEVE WHITE KNIGHT HAS A PRODUCT ON THE MARKET CALLED TILE AND LAMINATE PRIMER. NOT TOO SURE IF YOU'RE ABLE TO PAINT OVER NORMAL COLOURS OR IF THEY HAVE THEIR OWN SET RANGE.
ANOTHER WAY IS BY SANDING IT BACK TO GET THE SHINE OFF THEN APPLYING A PRODUCT CALLED ZINNSER B.I.N. THIS IS A GOOD PRODUCT THAT CAN BE PAINTED OVER WITH ANY PREMIUM HIGH GLOSS ENAMEL. THESE ARE GOOD WAYS TO PAINT OVER YOUR LAMINATE BENCH WITHOUT REPLACING YOUR LAMINATE. EGGENZ 2004 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31283 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3808 The yellowing mainly occurs to white or very light colours. 1 2952 |
