Browse Forums Kitchen Corner 1 Dec 05, 2008 7:08 pm Does the kitchen sink have to go under the window? Or can you move the sink to the corner of counter without it looking funny?
_______________________________________ Looking for contemporary furniture for my house. Re: Does the kitchen sink have to go under t... 3Dec 06, 2008 6:18 am It depends a bit on the layout (as above) and a lot on your personal aesthetic.
Some people have to have everything centred and balanced in their kitchens, other people are less concerend about symmetry, especially when one had limited space. I think you can put your sink wherever you like as long as it fits into your work flow - that is, having good access to the sink in the manner that you would use it. Sinks on the end of benches and in corners can sometimes become restricted and difficult to use if not done carefully. So when placing your sink it bears to think about how you Stack your dishes before washing (if you do), Which side you bring your dishes to the sink from, and Where you stack your dishes after washing (if you do). Cheers, Earl Re: Does the kitchen sink have to go under t... 4Dec 06, 2008 9:02 am I think placing a sink in the corner could be a good idea especially in a small kitchen. There are some L shaped sinks especially designed for 90 degree corner bench. But if you have laminate or timber benchtops then a sink at the corner may create problems for the benchtop joints cos water may seep thru the joints eventually. Re: Does the kitchen sink have to go under t... 5Dec 06, 2008 11:39 am This is a Clark corner sink with a flickmixer tap
The benchtop is a one piece and square edged , so there no bench top joins Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ By KevinBrown Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Does the kitchen sink have to go under t... 6Dec 06, 2008 12:22 pm Strumer It depends a bit on the layout (as above) and a lot on your personal aesthetic. Sinks on the end of benches and in corners can sometimes become restricted and difficult to use if not done carefully. Aesthetic and ergonomic. That Clark sink looks a little awkward and cramped. I can imagine doing my back twisting to get into the space. The rinsing bowl looks fairly small and impractical. I would probably kepp a large portable tray that I fill with water to rinse and then put away instaed. Re: Does the kitchen sink have to go under t... 7Dec 06, 2008 2:20 pm dymonite69 Strumer It depends a bit on the layout (as above) and a lot on your personal aesthetic. Sinks on the end of benches and in corners can sometimes become restricted and difficult to use if not done carefully. Aesthetic and ergonomic. That Clark sink looks a little awkward and cramped. I can imagine doing my back twisting to get into the space. The rinsing bowl looks fairly small and impractical. I would probably kepp a large portable tray that I fill with water to rinse and then put away instaed. Yes its small, but in that particular kitchen there was only a total of 1 metre of benchspace to the right of that sink. Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Does the kitchen sink have to go under t... 8Jan 02, 2009 6:00 pm I think it is a personal choice if you like it better there and there is plenty of room and not in the ay etc in door way. The house we build we had the sink moved to another spot and closed up one of the walk ways through as it had three one from diining room,one from meals and one from family so we closed up the one from the meals.A least me ended up with extra cupboards. Have had stone benches with undermount sink (kitchen) and drop-in (laundry) and top-mounted basin (bathrooms) for coming up 13 years and not one chip/scratch of any kind.… 2 9673 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39469 |
