Browse Forums Kitchen Corner 1 Dec 05, 2008 5:35 pm Has anyone used diamond gloss... toffee mineral stone?
Would love to see a pic if anyone has it. We have a small sample here but I need to make up my mind by monday so not enough time to request a larger sample. Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! Re: Diamond gloss.. toffee mineral stone? 2Dec 05, 2008 7:00 pm hi seakyl, I haven't used toffee mineralstone, but have used pure mineralstone, which is nearly the same except without the browny/toffee bits. Here is a pic, there are more on my house of donuts thread (its in the pantry). I know it's not what you want but might give you an idea of what it looks like in a large piece, as the pattern looked the same as the toffee one in the laminex samples l had.
It does look like real stone! We are very happy with it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ edited to make my sentence make sense Re: Diamond gloss.. toffee mineral stone? 3Dec 05, 2008 7:35 pm that looks really great donuts!! maybe I will check that one out instead. Does the pure mineral stone look grey in real life? Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! Re: Diamond gloss.. toffee mineral stone? 4Dec 05, 2008 7:40 pm Yes it looks a bit grey. But not excessively so, I think (hope!) as it and the stone benches are the only bits of grey I have in my house, everything else is browny and warm colours! Re: Diamond gloss.. toffee mineral stone? 6Dec 05, 2008 10:12 pm Hi Kylie,
We're having the pure mineralstone - like dounuts - in our kitchen. If you can get to the Laminex show room in Murarie, they have a fantastic diamond gloss display area there. I can't remember if they have the toffee one on display, but you'll get a really good idea of how the diamond gloss looks compared to the normal laminex. I think I spent nearly 2 hours there looking at all the options Re: Diamond gloss.. toffee mineral stone? 7Aug 04, 2012 2:15 pm I'm thinking of using pure mineralstone also. I was advised against the gloss because it scratches too easily and I have a busy home w four kids. I liked the picture of the pantry that was posted. Is the edge join very noticable? Is this not the square wrap then? cheers Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6797 This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18193 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7646 |
