Browse Forums Kitchen Corner Re: Microwave Oven Shelf/Cavity 2Oct 30, 2008 5:05 pm i dont think that you need much space on the sides (prob 10mm each side) the important space needed is behind. and it depends on if you get one with the edge that makes it look built in.
By the way a little off the subject, did everyone know that most microwave doors are hinged on the left? makes you think about where you want to put it. Maleena Hardy Curiouser & Curiouser Vintage-Handmade-Interior & Colour Consultancy http://www.curiouserandcuriouser.com.au Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5159 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5640 Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would… 2 2083 |
