Browse Forums Kitchen Corner 1 May 14, 2022 10:27 pm I am purchasing a second hand kitchen. It has a waterfall stone island. How do I go about dismantling the stone. Do I have to cut the stone? Or try to dissolve glue? I'll need to take the 2 sides off to move it. Has anyone done this before that can let me know what they did? How much it cost? I'm confident removing the cabinets but not sure with stove tops. Re: Moving stone waterfall island 2May 15, 2022 2:09 pm The epoxy glue won’t dissolve. Best option would be to get a stonemason if you plan to reuse it. They will be able to diamond saw cut along the join and transport it safely and reinstall it for you. It might also be tough to get off the cabinets. Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72313 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6579 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7493 |
