Browse Forums Kitchen Corner 1 Feb 02, 2022 4:24 pm Hi everyone, TL;DR - old stove is 900mm wide but not very deep so don't know how to find a new stove that will fit the 600mm benchtop. I have an old kitchen that I am looking to do a quick reno/repair on (only needs to last about 3 years until we knockdown/rebuild so trying to do it in a cost efficient manner) The current electric stove is very old and has weird dimensions of 900mm wide but only 435mm deep. The benchtop is MDF and a touch under 600mm deep. All the new electric stoves seem to be 900mm wide but 530mm deep. There are slimline 900mm stoves but they are only 350mm deep (and so would leave like a 90 mm gap with the existing hole size) My main question is whether I could cut a bigger hole in the benchtop without compromising the structural integrity of it (since it would only be about 3-4cm of remaining benchtop on both sides if the stove were 530mm deep). I was thinking of reinforcing the benchtop underneath with a long thin piece of aluminium and wood. Otherwise, does anyone else have any suggestions of what I could do here? Was thinking of getting a budget stove like this: https://devanti.com.au/products/devanti ... ol-6-zones Thanks in advance! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Can my benchtop support a 900mm stove 2Feb 02, 2022 4:47 pm It will be fine. The actual cut out is 490mm so you will have roughly 50mm front and back. The front will have a rail behind the top of the drawers. Hopefully it's a vertical rail so you only have to cut through the benchtop and not the benchtop and rail all together. If it's a vertical rail just start your cut out 5mm behind it so you can still use any clips to hold the cooktop down. The back of the bench sits on the carcass and the front will be supported by the front rail. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 12409 4 3820 Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12938 |
