Browse Forums Kitchen Corner Re: Fridge height - feet/ legs included? 2Dec 03, 2021 7:44 pm It's the installed height at the lowest level. If you need adjustment it will go up a bit but you shouldn't need much. What is important is a bit of space for the fridge to be able the vent off the hot air from behind. Some manufacturers specify a height above their fridges in the manuals. A fridge in too tight a space will work inefficiently and cost you more to run. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20850 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7498 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10583 |
