Browse Forums Kitchen Corner 1 Aug 31, 2021 6:33 pm Hi, Got a some new kitchen cabinets installed, and they all work great, except for the 2 large cutlery drawers. They are large (75 cm by 10 cm), and soft close and push to open using Blum components. Problem is if I don't give them a reasonable push to close then they bounce back open and don't close. So if I push hard they close, but if I push softly they nearly close but then bounce back (like theyhit a spring or something) The plate drawers under them are not push to open but are Blum soft close and work perfectly. Kitchen company says this is normal with push to open soft close. Are they correct ? cheers Jon Re: Blum soft close kitchen drawers bounce back 2Aug 31, 2021 6:52 pm Hi Jon Yes it is normal. I'd say you don't have anything in the drawers currently. The triggers that open the drawers come in different weight ratings depending on the assumed load the drawer will take. An empty drawer doesn't have enough weight to overcome the trigger so they tend to bounce open. Once you put weight in the drawer you will find they close nicely. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Blum soft close kitchen drawers bounce back 4Sep 01, 2021 4:42 pm Ok, thanks for the replies. We only have push to open on the top bank of drawers (as they abutt the porcelain countertops), and they are reasonably loaded with cutlery / knives etc. About 60 in one drawer. I assume no adjustment possible ? - they really need a fair push to get the soft close not to bounce back. The 2nd and 3rd drawers down aren't push to open, as they have finger grips on the top of them - but these close with little pinky finger pressure. Very nice. Just need to remember which drawer I am closing I suppose. cheers Jon. Re: Blum soft close kitchen drawers bounce back 8Sep 01, 2021 5:12 pm Hi Jon As I mentioned above the trigger units come in various weight ratings dependant on the size of the drawer and the assumed weight. Obviously a heavily loaded drawer needs more of a push from the trigger unit to get it open (and conversely closed). It may be that they have put a heavier trigger unit on your drawers than is required. This will spring the drawer open further but also require a bit more of a push to close. The trigger units are replaceable (for different weights) but not adjustable as far as closing pressure goes. The different drawer runners (soft close and tip-on) are the same, it's just the trigger unit that gives the tip-ons the push to open function. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Blum soft close kitchen drawers bounce back 9Sep 01, 2021 5:15 pm I just watched your video. That is pretty standard. They do take a bit of a push to get past the trigger where as the standard runners don't have the trigger so pull in with no bounce. You could ask them to put the lightest trigger on the drawers. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Blum soft close kitchen drawers bounce back 11Dec 25, 2022 12:51 pm We have a Blum cutlery drawer which has worked well for years, but recently after normal closing bounces open by about 2-3 cms. Any suggestions as to how to fix this? Re: Blum soft close kitchen drawers bounce back 12Dec 25, 2022 1:19 pm Hi Steve There are several different types of Blum drawer systems that incorporate soft close. Is it push to open or just soft closing? What do the drawer sides look like, are they single wall or multiwall? It's possible that the soft close mechanism has broken but it all depends on what system you have. If you could put up a picture of the drawer sides or maybe even a short video of exactly what happens I can give some more information. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3320 Like pulse said, you can fit drawers however because of the placement of the sink there isn't much depth so you would have to have cut outs for the waste pipes. It all… 2 1304 Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15306 |
