Browse Forums Kitchen Corner 1 Oct 12, 2008 4:37 pm Hey all
We are just in the process of getting setup in our new house and we are looking to install our dishwaster. We had a recess put in by the builder so there is power and holes drilled through the kitchen cupboard etc. The query I have is that where the dishwasher connects into the plumbing under the sink there seems to be a hard plastic cover/cap on the connection, is it as simple as knocking it out with a screwdriver and the connecting it all up?, or does it need say a hole drilled through it, it does look relatively solid. I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 1871 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 5347 For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 5269 |
