Browse Forums Kitchen Corner 1 Oct 05, 2008 10:12 am Hi this is my kitchen. I will rent out my house so it will actually be an IP.
I want to makeover the kitchen without replacing the cabinets if possible. I.e. I dont want to do a total reno. I just want to modernise it and get a good rent. I plan to: Replace the splashback as I am getting the floors tiled anyway. Get a new wall oven. Get a new stove top Replace the cupboard door handles. Put up new lights. Put up wooden blinds. Perhaps paint the cupboards and cabinetry. Perhaps replace the taps Is that what you would do on a low budget? Could you please provide feedback and ideas. Issues: 1.Could I just paint over the ugly brown tiles? 2. If I cant get a stove top that will fit in the hole from the old stove top (90cmx40cm) what would you recommend I do? 3. Similar with the stove, I would need to 'pack' any new stove i.e. replace the panel it sits in because new wall ovens are a lot smaller. Is that hard to do? 4. Has anyone ever gone with those spray-on bench surfaces that makes it look like granite? Is that good value? 5. Is it easy to replace those kind of taps. Would it make a difference? Thanks for your help Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am renovating a 3 bed house. I have no trades experience but I am keen to learn how renovate. I really appreciate the advice people give me here because I dont have a car so it is hard to get around trades places to talk to people. Re: Advice wanted on cheap kitchen reno see photos 2Oct 05, 2008 10:46 am With the stove, if you fill in the hole, then any cook top will fit
or use a sheet of stainless steel over the hole Relaminate the benchtop over you existing top, yours looks like square edge Taps can be replaced with a flick mixer, then cap the other two holes with chrome caps available from plumbing stores Wall oven:- Try a cabinet makers shop for an offcut, If the colour is no longer available, replace the panel behind it, with either a matched spray painted panel or sheet stainless steel Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Advice wanted on cheap kitchen reno see photos 3Oct 05, 2008 10:47 am Hi Gatoblanco,
Firstly, welcome to the forum...looks like you've got a big job in front of you. I don't know much, but will help with what I can. Quote: 1.Could I just paint over the ugly brown tiles? Personally, I wouldn't do this. As you have said if you are already getting a tiler in it shouldn't cost you too much more to put in new tiles. Quote: 2. If I cant get a stove top that will fit in the hole from the old stove top (90cmx40cm) what would you recommend I do? Not sure, but maybe you could google a few different stove tops to find out their measurements. Quote: 3. Similar with the stove, I would need to 'pack' any new stove i.e. replace the panel it sits in because new wall ovens are a lot smaller. Is that hard to do? I have seen a few double ovens around, which may fit in there...again try googling to see what you can find. Don't know how easy it would be to pack around it, but I'm sure one of our kitchen gurus would know. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Quote: 4. Has anyone ever gone with those spray-on bench surfaces that makes it look like granite? Is that good value? Haven't heard of this, but a few people in the past have looked at Granite transformations. Search the forum for Granite Transformations and you might find some info on costings etc. Quote: 5. Is it easy to replace those kind of taps. Would it make a difference? Taps should be no problem. We also have an older rental property and have found that just updating the taps really lifted the kitchen and for very little cost. Also you mentioned painting the cupboards. Another member, Batesy has recently done this in his kitchen. https://forum.homeone.com.au/viewtopic.p ... c&start=30 Goodluck Oh and btw, you look the spitting image of my brother in your avatar...It's quite disconcerting 'chelle We have a hand-over date...15/10...but I won't hold my breath! http://people-in-glass-houses.blogspot.com/ Re: Advice wanted on cheap kitchen reno see photos 5Oct 05, 2008 11:15 am Hi Gatoblanco, welcome to the H1 forum. You will find lots of great info and good ideas from everyone and you came at a good time.
We did a couple of kitchen renos a few years back for similar reasons. Luckily DH brother is a cabinet maker so that helped. But what we did on a tight budget to tidy up was............. Replaced the benchtop with a new one....White New upright fresstanding oven and cooktop in one. Painted the splashback tiles white.....(there is a (I think its called) White Night product) you can prime the tiles with this and then paint over. We tested them after with screwdriver and the paint didn't chip or scratch. Retiled the kitchen/dining in the one tile so it looked more spacious. Used steel wool on the sink and it came up like new Replaced cupboard doors and handles Took down overheads and painted and put some wall shelves up so it felt more open. and replaced the light fitting. I think all up it cost us $5000 Good luck, its very rewarding at the end when you see the finished product. Re: Advice wanted on cheap kitchen reno see photos 6Oct 05, 2008 11:29 am What you should consider is getting a price for a complete flat pack kitchen.
Compare this price to what you will/might spend on rehashing your existing kitchen Once you have this info in hand, you will have a better idea of the best way to go There are several people on this forum that could supply you costings on a flat pack. Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Advice wanted on cheap kitchen reno see photos 7Oct 05, 2008 12:19 pm Kevin Brown What you should consider is getting a price for a complete flat pack kitchen. Compare this price to what you will/might spend on rehashing your existing kitchen Once you have this info in hand, you will have a better idea of the best way to go There are several people on this forum that could supply you costings on a flat pack. Well worth thinking about - if you are thinking about replacing appliances then I would definitely suggest that you consider upgrading the cabinetry to suit. If you just want to give your kitchen a bit of a cosmetic "freshen up" then stick to the painting/relaminating the benchtop and new handles. Since you plan for it to be an IP my recommendation is that you spend a bit more money on new materials at the outset as these will provide the most durable and longest lasting result with the least liklihood of maintenance during a tennancy. If you are going to replace your oven you will find that most new models are probably narrower as well as less tall, which means that you could gain a few extra cm by fitting a smaller wall oven unit - this design would also provide an oportunity for the microwave. Similarly rather than trying to find a 900mm wide cooktop to replace the existing unit you might do better to find a nice simple 600mm model and put the extra money in to a new benchtop instead. If you are looking at new appliances there are a few good "entry level" packages available such as those provided by Chef, or the Platinum range from Nover - which can include a new 1 1/2 sink and flick mixer for under $200.00 If you have a good dimensioned drawing of your space there are a few people around that can give you genuine indicative pricing for your specific layout. Cheers, Earl Re: Advice wanted on cheap kitchen reno see photos 8Oct 05, 2008 7:41 pm If the cupboard doors are in good condition I would just change the handles. Definitely change the benchtop to white or else, if budget affords it, change it to stone. If your point is resale, then it would definitely go down a treat. If the sink comes up well with a good polish say bicarbonate of soda is really good then I would leave it and rather use the money for your appliances and benchtop. Get rid of the blinds. I believe you can also paint over tiles if necessary. Ask at the hardware store. Re: Advice wanted on cheap kitchen reno see photos 11Oct 05, 2008 11:40 pm Regarding the cooktop: I've had one positioned the same way as yours is. It is a PITA to use. There is not enough space the stand properly to cook. If you can (not sure if there are rules about this but someone will know), I would place the new one on the bench that's under the window. Much easier.
Judie Re: Advice wanted on cheap kitchen reno see photos 12Oct 06, 2008 5:18 am Judie Regarding the cooktop: I've had one positioned the same way as yours is. It is a PITA to use. There is not enough space the stand properly to cook. If you can (not sure if there are rules about this but someone will know), I would place the new one on the bench that's under the window. Much easier. Judie Re:- placing the stove under a window , curtains can catch alight Better to maybe place an upright stove where the wall oven is now. It's usually better to use an upright stove in rental propertys. They are easier & cheaper to replace than the built in type, due to no cabinetry top worry about Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Advice wanted on cheap kitchen reno see photos 13Oct 25, 2008 1:07 pm Oh my gosh! That looks like our old kitchen!
The benchtop looks like our old one too but ours was a horrilble pink colour! You should probably stick your head in the cupboards and have a good look at the benchtop top and cupboards, as we ran into a probelm... There was a gap between the top of the benchtop and to where the cupboard doors started. Hence that big edge around the benchtop. So that may cause a probelm there. We ended up ripping the whole thing out and starting again! I would have a go at tiling! I've done it twice now and never done it before and I was quite suprise at how easy it is!! You'll be much happier with the result than painting the tiles. Plus you maybe able to pick some tiles up for a bargain price! You could really save some money there! I would replace the handles and paint the cupboard doors with laminate paint. There is a company that can cover the benchtops with a panel type of material that looks like granite... Have fun!! First time home owner and first time renovator... Re: Advice wanted on cheap kitchen reno see photos 14Nov 02, 2008 9:26 pm Thumbs up for White Knight Tile&Laminate paint from me.
I used it to do my kitchen splash back tiles, cupboard doors and cupboard sides. Fix any chips/dings in your doors with some this then sand: http://www.selleys.com.au/Selleys-Knead ... fault.aspx Prepare using some wet&dry paper, wipe down with methylated spirits on a rag, then apply primer. It's got 1hr touch dry, 4 hour re-coat times. Next day apply top coat with a fine brush. Then later a second top coat. I found that for large cupboard doors I needed to work quickly to get an even coat before it got sticky and gave a slightly less than perfectly even finish. The primer goes on thick (water based) but the top coat (turps cleanup) evaporates quickly and also soaks into the primer (by design). Leave it a full week before use to allow the layers of paint to fully harden. It covers old patterns and pictures in tiles no problems. New door handles then make all the difference. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer… 0 8324 Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10372 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8773 |
