Browse Forums Kitchen Corner Re: Do Handle-less Drawers Sit Flush as Standard? 21Aug 19, 2014 6:13 am I totally agree with chippy, the front set backs are totally wrong!! 45-60mm at the front is a fairly normal size which gives more room at the back. I believe both your appliances can and will fit into a 600mm bench top when done properly. The fault ****** with the stone mason!! When you say they installed "quartz" what does that mean?? CaesarStone is a quartz based product. If they didn't install CaesarStone what did they install?? Dig your heals in and don't pay another cent! The stone needs to be replaced with what you paid for and the appliances need to be cut in properly!! Do you have a contract for the kitchen?? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Do Handle-less Drawers Sit Flush as Standard? 22Aug 19, 2014 8:03 am If you look at the attached image I believe this is what has happened, it's a combination of: Cabinetmaker having not checked appliances, Installer who cut templates not thinking & stonemason who accepted the templates as is. This is a huge issue as most appliances wont fit. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Do Handle-less Drawers Sit Flush as Standard? 23Aug 19, 2014 9:04 am By the way, from the images shown it looks like an undermount sink, or flush fitting, either way its been installed as a top mount. This job is a total cockup! Re: Do Handle-less Drawers Sit Flush as Standard? 24Aug 19, 2014 4:47 pm Looks like Sonny uses Solid 6.1 Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: Do Handle-less Drawers Sit Flush as Standard? 25Aug 20, 2014 7:09 am Sonny2014 If you look at the attached image I believe this is what has happened, it's a combination of: Cabinetmaker having not checked appliances, Installer who cut templates not thinking & stonemason who accepted the templates as is. This is a huge issue as most appliances wont fit. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yep, that is a possibility. Looks like no one has paid any attention to the appliance specs or understands you need to build things slightly differently with handless. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16221 Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3644 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 2881 |
