Browse Forums Kitchen Corner Re: dishwasher plumbing dilemma 22Jun 01, 2010 9:53 pm Is the pressure low with both hot and cold. There are sometimes screens down stream of the mixer in either the flexible hose or the base of the tap itself that prevent debris getting into the mixer, it could be this. First thing to check though is if the plumber turned the water back on fully out at the meter. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: dishwasher plumbing dilemma 23Jun 02, 2010 2:38 pm Hi Chippy, thanks for your input....not sure about the debris collector in the flexi hoses but I checked the water supply tap at the front of the house and it's fully opened. Also, the pressure is the same for the hot and the cold supply. It's not really a problem I guess...I just wondered why it had changed and if it had something to do with that 'tee' connection'? Re: dishwasher plumbing dilemma 26Jun 02, 2010 3:37 pm talking about the main connection tap. At the front of your property near your meter. If he worked on your plumbing there is a good chance he had to turn it off for a while. I was thinking that when he turned it back on he didn't open it all the way. I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2903 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6394 Hi Sillysausage1900, Hope all is well. I came across this forum as Im somewhat same situation with you regarding Roof Plumbing certificate requirement. Im requesting a… 4 9645 |
