Browse Forums Kitchen Corner Question RE power and pipes for island bench 2Apr 23, 2012 6:17 pm Lot927 Hi We will be having an L shaped island bench in the kitchen. There is a stormwater sized pipe that comes out of the concrete, inside it has pipes coming out of it for hot and cold water and also there is conduit for power... inside the stormwater pipe is water. I just does not seem right to have power coming of this, is this normal? Thanks The water that you are talking about, that sounds like water that has gotten in there while the slab was open to the elements, ie before the roof went on. Is that right? It is one of the things to mentally list to check that the builder removes the water before too long as it will get pretty rank after a while. Same as the water in the hole they leave in your slab to allow access to the pipes under your bath. That often is full of water and rubbish, pays to check they empty that before enclosing it fully with a tiled hob. Ray153 HD Re: Question RE power and pipes for island bench 3Apr 23, 2012 6:20 pm Ok.. will check that off with the SS... but I wonder how will our sink/dishwasher drain? It just seems like there are not enough pipes.... Re: Question RE power and pipes for island bench 4Apr 23, 2012 7:24 pm Yeah I know what you mean. I questioned the same thing with our build, but apparently that is the way it's done - one pipe that has heaps of other pipes running through it Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11316 4 6160 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 6025 |
