Browse Forums Finishing Touch 1 Mar 05, 2018 9:37 pm Am about to embark upon a big reno on an old queenslander. The paint has some old lead layers and was painted last in the 80s, where it cracked after little time from a miss match of paint types. While the boards are seemingly above board, a great majority of the paint is flaking off. I have done a large area with an American tool, the Paint Shaver Pro, but it has left the corners and was too hard to get into some areas. There is a lot to do with a heat gun, if I want to get it to the bare wood that the shaver tool did, and I would probably have to sand it after that anyway (it seems like you don't have to sand the shaver tool's areas really). Can you use too much builders bog? Should you bog before or after priming? Comments? AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6278 4 14466 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7048 |
