Browse Forums Finishing Touch 1 Aug 28, 2008 10:54 am HI guys, I thought I would share my idea for my left over floor tiles at the last house................
We had tiled our alfresco in some really nice tiles 300x300 and we had nearly a whole pack left over. So I didn't want them to go to waste and hubby wanted to keep them for"just in case". So I grabbed some felt feet (flat ones) that I have been using for decorator pieces that I feel might scratch furniture......tables, buffets etc and put them on the bottom of my tiles and I use them as my placemats for our alfresco table. Washable and they don't fade (like my expensive wood ones did when i left them out there one sunny day) and when hubby cooks charcoal steak your plate doesn't move around trying to cut it. Its not everyones taste but its simple and effective.... Re: An idea for left over floor tiles................ 2Sep 01, 2008 9:51 am Nice idea!!!
Come on where are the pics???? Re: An idea for left over floor tiles................ 3Sep 01, 2008 10:28 am Ok....Sorry I know how we like pics on here, I completely forgot.
This is the tile itself.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This the underneath where I have applied the protector.....sorry its a bad pic Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The tile set up outside....I put vanilla tealights in the cups for a bit of effect. and I layer the plates for the different meals..Saturday we had people over it was finger food and nibblies and these plates did the trick. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So thats how I use them.......It also dresses up the table..... Thinking about it, you could proabably go and buy 8 tiles from the tile shop if you wanted also and get different sizes to layer........ Re: An idea for left over floor tiles................ 4Sep 01, 2008 10:34 am Sorry my pics are huge. I'm not sure yet how to reduce them so that they look normal when posting. Practice will make better. Re: An idea for left over floor tiles................ 6Sep 01, 2008 10:54 am I like!!!! Layering with colours/textures would be great too!!!
The mind is ticking as i type!!! Thanks for that! To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 408 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3661 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8070 |
