Browse Forums Finishing Touch Re: Plaster skim coat over painted render 6Oct 07, 2018 11:56 am Hi Captincaveman I'm looking in to renovating my house and have the same issue you had. I'd like to paint the walls but that are finished with a rough plaster that has been painted so meny times they current finnish coat is really rough. I've tried sanding back the paint and some of the existing plaster, unfortunately the plaster h as small stones in it that has given it the right finnish and sanding will not fix the issue. I'm thinking I'll have to skim coat over the but not sure how well the is will work. I'd like to know how you dealt with your place, what products you used, how when it worked and if you'd recommend doing the same. Cheers Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5025 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5295 |
