Browse Forums Finishing Touch 1 Aug 02, 2015 9:49 pm Just got a painter's quote for entire inside of a town house (ceilings, walls, doors, architraves - all white). Quote includes prepping etc plus painting front fence & a big side gate. We haven't had any other quotes, I really just wanted it done by these guys as they'd done work for a friend. Two painters - 11 days. They've quoted $1200 to supply paint then their hourly rate works out $40 per hour. $8364.00 Being a bit naive probably, but thought the quote would be quite a bit lower but ...... thanks in advance J Life is like a lolly, suck it and see Re: Painter's quote? 3Aug 02, 2015 10:20 pm Hi, thanks for your response just copied & pasted quote below. 2 story townhouse - 15yrs old. Maybe about 21sq? I'm guessing, sorry. Yes, just the one quote. Don't have time to get more at this point ... was hoping these guys were ok! Prep and sand 13 doors. Prep and sand 17 architraves. Prep and sand 10 windows. Prep and sand all skirting’s Undercoat with Acrylic paint all areas where there’s filler Undercoat air vents on ceilings with Oil based undercoat Fill and gaps and holes in the 14 rooms/areas through out the house One coat of Acrylic paint on the ceilings and walls in the 14 rooms ( Flat Acrylic, Natural One coat of Oil based paint on all the wood work:- Doors, architraves, windows and skirting’s ( low shine, AW usa ) Outside Property:- Prep and gap holes on front of house. Sand posts. Paint ceiling and paint posts Prep front fence and side gate. Two coats of weather shield paint ( colour not decided ) Supply of labour/ workmanship for 11 days work for two men Cost Includes $1200 for paint and materials Life is like a lolly, suck it and see Re: Painter's quote? 4Aug 03, 2015 8:31 am The above shows that there is actually quite a bit to do. I think it is hard to get your head around as it is something you could potentially do yourself and not pay for the labour. You could try and do, for example, one room yourself and see how long it takes. It is more labour intensive than it looks, and time consuming. $40.00 per hour is quite a good rate, I think, it is just that it is x 2 and for many hours, which adds up. Using professional painters will give you a professional look and it will be done before you know it. My blog: tashandpaul.wordpress.com Re: Painter's quote? 5Aug 03, 2015 12:26 pm Here are some thoughts on DIY painting a complete house. http://www.anewhouse.com.au/2014/04/diy ... -worth-it/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Painter's quote? 7Aug 05, 2015 10:41 pm Flat acrylic on all walls is a worry. It should be at least matt, and if that; only one Australian paint manufacturer has a matt strong and washable enough to consider for longevity. Suggest low sheen, you deserve it for that quote. They will probably kick back at this request as flat is easier for them as it is harder for you to spot imperfections. if that is the case and you cant win, settle for matt. $1200 is very cheap for paint. Suspect poor quality paint is being used. All in all, id consider another quote. Re: Painter's quote? 8Jul 01, 2016 1:52 pm I think that price sounds about right. I would make sure the paint is a good quality one. I personally wouldn't use anything but dulux hey there! 😊 so, it’s kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20920 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14323 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12408 |
