Browse Forums Finishing Touch 1 Jun 29, 2008 10:52 pm The house we are building has a robe which we walk through to access the ensuite. The robe is a shelf and rail U-shape, however I find the U-shape rail tends to have a 'dead zone' in each of the back corners which you can't use for anything.
I was having a play around with paint and came up with the image in the attachment of having more of a 'dressing room' with a window and mirror. Any feedback would be appreciated. The robe is 3.2m x 1.8m with a 90cm walk-through and 40cm deep shelves. We can only have a shelf and rail due to budget constraints! http://i291.photobucket.com/albums/ll31 ... robe-1.jpg http://i291.photobucket.com/albums/ll31 ... robe-1.jpg Matrix Re: Wardrobe Options 2Jun 29, 2008 11:10 pm Er....do you mind if I...no....OK.....
Matrix http://i291.photobucket.com/albums/ll315/matrix13_album/Originalrobe-1.jpg Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Matrix http://i291.photobucket.com/albums/ll315/matrix13_album/Newrobe-1.jpg Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Wardrobe Options 3Jun 29, 2008 11:18 pm Even though you think you will have a dead zone with the U shape, you will have more space in the long run.
Eventually you may have the budget to fit it out and there are some great corner solutions you can use. Here is a photo of a wardrobe (bigger than yours) but you will see how much you will loose by putting in a window or mirror. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ See how the long hanging goes into the corners? You could put shoe racks at each end - at this point a cheap bookshelf will do the job. Paula Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3043 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4878 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 11999 |
