Browse Forums Finishing Touch Re: Wardrobe Options 2Jun 29, 2008 11:10 pm mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3062 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4895 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12035 |
