Browse Forums Finishing Touch 1 Aug 14, 2014 12:08 pm Our painter (a professional) painted over doors which were already painted in gloss, with our choice of Dulux Gloss paint. It appears to be a single (or maybe 2) sprays and there does not appear to be any primer or undercoat used. Now they are scratching so easily with paint literally peeling off when scratched. The corner of a cardboard box causes the paint to scratch to the original paint let alone my toddler peeling off the paint. My questions: 1. Is there any solution such as repainting with a laquer/polyurethane or other product to seal the paint 2. Proff painters - are you supposed to prime over gloss before painting over (I always, have but I'm not a professional) Rgds Re: Help with painting over Gloss Paint. Help! Help! Help! 2Aug 25, 2014 10:55 pm I dont think anything over the top will help as the 2 coats have not bonded together. Sand the doors back first, prime than final coats and always allow drying times as directed. Re: Help with painting over Gloss Paint. Help! Help! Help! 3Sep 15, 2014 1:56 pm Ask him to come back and fix it. generally you don't have to prime it again if the existing surface is good, but wipe it down with mineral turps to make sure it's clean and then give it a light sand if it is old. I'm surprised it has occurred if a pro painted it. Re: Help with painting over Gloss Paint. Help! Help! Help! 4Sep 18, 2014 8:17 pm Sounds to me like he sprayed water based gloss over enamel. If that's the case it'll never stick. Needs to be sanded right back. How long did it take to dry? If less than 24hrs then it's acrylic. Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18151 |
