Which of these 2 front doors look better?
Door 1:
Door 2:
Browse Forums Finishing Touch Re: Which of these 2 front doors look better? 2Apr 08, 2014 8:42 am Door 2 being more geometric seems to have the effect of "widening" the doorway. Re: Which of these 2 front doors look better? 3Apr 08, 2014 8:56 am Sorry, I just mucked up your results by making it three all! What I like about door 1 is that it gives a bit of visual contrast. All the lines seem to be parallel and this one is perpendicular and picks up the LHS window theme - but I have to admit I have no artistic talent. Re: Which of these 2 front doors look better? 4Apr 08, 2014 9:07 am Ok thanks guys. Yes both good points. I like door 2 as it runs with the horizontal lines of the garage and house but door 1 is different and breaks up the lines.. Keep the suggestions coming people Re: Which of these 2 front doors look better? 8Apr 09, 2014 10:14 pm I may be biased as door 2 is the one we went for.... so great choice! We have had the glass inserts frosted, for a bit of extra privacy. Re: Which of these 2 front doors look better? 9Apr 26, 2014 6:41 am We left the glass clear are our house is elevated and there are no houses across the street and we wanted to let as much light in as the front door just looks on a hallway as the house is a split level. Re: Which of these 2 front doors look better? 10Apr 26, 2014 7:56 am I think I prefer the 2nd. But either look good imo. brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7649 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1776 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12471 |
