Browse Forums Finishing Touch 1 Feb 23, 2014 1:17 pm Google is failing me here and Boral rep was unable to provide me with any example addresses for houses using the bricks. Trying to keep costs down so looking at staying within my builders standard brick range, which is Boral Horizon's range. Has anyone built their house using the following bricks, and if so, would you mind posting a photo? - Granite - Longreach - Springbrook - Khaki - Emerald Cheers. My Noosa 23 Build - viewtopic.php?f=31&t=72782 Re: Boral Horizon brick range 2Mar 03, 2014 8:22 pm Post this up in the building forum someone is bound to have used the bricks in their build. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com 2 8405 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12176 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7308 |
