Browse Forums Finishing Touch 1 May 15, 2012 9:05 pm Hi there, Just wondering if people really are moving away from gloss for woodwork (skirting, architraves and doors)? 2 shops have told me this now. And what is the go for walls these days - some sort of satin/sheen finish or plain matt? THANKS! Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Which paint for which surface? 2May 15, 2012 9:22 pm l wanted semi gloss on trims/doors,was told that there is very little gloss meaning doors,trims and walls will all appear same no contrast (if you are having low sheen.lf walls are low sheen and trims are high gloss you get a contrast using same colour,as gloss reflects more light.lt's only whites with no tint that goes yellow(l can be corrected on that) Re: Which paint for which surface? 3May 16, 2012 8:28 am great thread... I had no idea there were so many finish options, let alone colours! SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Which paint for which surface? 4May 16, 2012 1:34 pm Hey Pattycake - thanks! I have doiscpovered there is a wtaer based gloss now that does not yellow, so have asked for that with a low sheen on the walls. Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Which paint for which surface? 5May 16, 2012 1:46 pm We just painted and used semi gloss for all the woodwork, I was told the higher the gloss three more noticeable imperfections are! I think all the walls where low sheen, we also used two colors, seems that's not done so much anymore either 2 Re: Which paint for which surface? 6May 16, 2012 2:57 pm Hi Stormjr - thanks! Do you mean 2 colours for walls and woodwork - or 2 colours for walls? Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Which paint for which surface? 7May 16, 2012 3:40 pm stormjr,,does semi have a different shine or is it same sheen as your walls low sheen?.l still want to go semi gloss(oil base) any pics? Re: Which paint for which surface? 8May 16, 2012 5:53 pm nina marie Hey Pattycake - thanks! I have doiscpovered there is a wtaer based gloss now that does not yellow, so have asked for that with a low sheen on the walls. Which one is that? What brand? SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Which paint for which surface? 9May 16, 2012 6:01 pm l don't think any brand water based gloss (white)will yellow. l can be corrected Re: Which paint for which surface? 10May 16, 2012 6:44 pm One color on the wall, but all the door trims are a different color, and some of our walls have timber paneling on them, that is painted in the semi gloss, all water based acrylic. I think that there is a difference in the shine level between the two 2 Re: Which paint for which surface? 11Jun 01, 2012 3:02 pm Any acrylic enamels (water-based enamels) will not yellow over time like solvent/oil based enamels.
Dulux Aquanamel, Solver Aqua trim, Haymes Ultratrim, Resene Enamacryl are just a few. Acrylic enamels are more user friendly being water clean up, not turps, etc. I try to stay away from oil-based enamels these days unless I need them as they have a tendency to yellow in dark areas. A good quality high-gloss acrylic enamel will come within 90% of the gloss of a high-gloss oil-based enamel. As always the level of gloss depends on the quality of paint. Resene and Haymes semi-gloss acrylic enamel has a better finish than some brands high-gloss! There is a huge difference between semi-gloss trim and low sheen walls. 90% of homes that I repaint now are low/mid sheen walls and semi-gloss trim. It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8240 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36949 |
