Browse Forums Finishing Touch 1 Oct 11, 2011 11:29 am Hi there, I've just paintes with a hi gloss oil based over a well sanded waterbased window frame with no primer. What can I expect? Should I just re-sand and start over or will it be ok for a few years? It's an internal window frame. Many thanks, Re: Painting with oil over water based 2Oct 12, 2011 5:15 pm You can paint over water base with an oil base, but you shouldn’t paint over oil base with a water base. So you should be ok! That’s what a painter told me and the guys from my paint store. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Painting with oil over water based 3Nov 04, 2011 5:40 pm Michelle You can paint over water base with an oil base, but you shouldn’t paint over oil base with a water base. So you should be ok! That’s what a painter told me and the guys from my paint store. Really??? When sealing problems (nicotine, smoke damage) I've always been told to use an oil based primer (or zinzer) then water based or whatever.. Re: Painting with oil over water based 4Nov 04, 2011 7:02 pm application methods vary with different brands and products There are water based paints that (after applying primer) can be applied to substrates that have been painted with oil based. With nicotine/smoke damage there is a preparation product I would specify that is oil based, to which water or oil based paints can be applied. Re: Painting with oil over water based 5Nov 14, 2011 6:23 am 4walls application methods vary with different brands and products There are water based paints that (after applying primer) can be applied to substrates that have been painted with oil based. With nicotine/smoke damage there is a preparation product I would specify that is oil based, to which water or oil based paints can be applied. And what product would that would be please? I will be painting a fire damaged house and want to get the preparation right. I was under the impression that I could use any oil based paint/primer to seal it then paint with water based paint. I know when I painted over gloss paint I applied something first before painting the water based. Do I need to do that? or add something to the paint? Thanks. I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1938 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10974 Hi We are building in the Hunter Valley, our soil test is H1, our builder has advised us they need to have a letter signed for Fair Trading as the new drainage standard… 0 3554 |
