Browse Forums Finishing Touch 1 Jun 05, 2011 9:33 pm Hi all, first time poster here. I'm nearing the end of a major Reno (will post pics ASAP) and we are trying to decide if we should use water or oil based paint for skirting, door, window frames and doors. Colour will be white on white so I am mindful of finger prints on doors etc. Any suggestions? I'm leaning towards water based... Re: Paint advice needed help 2Jun 08, 2011 9:32 am Hi, If you are painting yourself water based is alot easier to work with and will produce a better job than if you were to attempt oil based, but if you are paying a painter to do it then you cannot beat oil based for durability. Regards Simon Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7171 |
